Testing a priority queue with Monolith
- November 19, 2025
A priority queue is a data structure whose specification is
non-deterministic: indeed, if a priority queue contains several
key-value pairs whose key is minimal, then any such pair can be legally
returned by pop. In this blog post, I describe how to test
an OCaml implementation of a priority queue using Monolith.
Suppose that we have written (or someone has given us) an implementation of (immutable) priority queues. The signature of this module might look like this (LeftistHeap.mli):
module Make (Key : sig
type t
val compare: t -> t -> int
end) : sig
(**A key. *)
type key = Key.t
(**An immutable priority queue. *)
type 'a t
(**[empty] is the empty queue. *)
val empty : 'a t
(**[singleton k v] is a singleton queue containing the key-value
pair [(k, v)]. *)
val singleton : key -> 'a -> 'a t
(**[merge q1 q2] merges the queues [q1] and [q2]. The result is a
new queue. *)
val merge : 'a t -> 'a t -> 'a t
(**[pop q] extracts a key-value pair whose key is minimal out of the queue
[q]. [None] is returned only in the case where [q] is empty. *)
val pop: 'a t -> ((key * 'a) * 'a t) option
endThe implementation of this module might be based on Chris Okasaki’s leftist heaps, a simple and beautiful data structure (LeftistHeap.ml). But this does not matter. Let’s see how to test this implementation as a black box using Monolith (paper).
Monolith expects us to provide a reference implementation of a priority queue. This reference implementation does not need to be very efficient; what matters is that it should be simple and correct. The simplest possible approach is to use an unsorted list of key-value pairs, along the following lines (reference.ml) :
type t =
(Key.t * Val.t) list
let empty : t =
let singleton k v : t =
[(k, v)]
let merge q1 q2 : t =
q1 @ q2
(* missing [pop], for now *)Here comes the interesting part. pop is a
non-deterministic operation: if a priority queue contains several
minimal key-value pairs, then any of them can be legally returned by
pop.
In such a situation, the candidate implementation of pop
makes a choice. It would not make sense for the reference implementation
of pop to also make a choice: because the two choices might
be different, the candidate and the reference could become out of
sync.
Instead, we want the reference implementation of pop to
check that the choice made by the candidate implementation is legal and
to obey this choice, that is, to make the same choice.
Therefore, the reference implementation of pop cannot
have type t -> ((Key.t * Val.t) * t) option, as one
might expect. Instead, it must take two arguments, namely the queue on
the reference side and the result returned by pop on the
candidate side. It is expected to return a diagnostic, that is, an
indication of whether this candidate result is valid or invalid. The
type diagnostic is defined by Monolith (documentation);
its constructors are Valid and Invalid.
The reference implementation of pop can be written as
follows (link):
let pop (q : t) (result : ((Key.t * Val.t) * _) option)
: (((Key.t * Val.t) * t) option) diagnostic =
match result with
| Some (kv, _cq) ->
(* The candidate has extracted the key-value pair [kv] and has returned
a candidate queue [_cq] that we cannot inspect, as it is an abstract
data structure. Fortunately, there is no need to inspect it. *)
(* Check that the key-value pair [kv] chosen by the candidate is a
minimal element of the queue [q], and return [q] minus [kv]. *)
handle @@ fun () ->
let q = remove_minimal kv q in
valid (Some (kv, q))
| None ->
(* The candidate has returned [None]. Check that the reference queue [q]
is empty; if it isn't, fail. *)
if q = [] then
valid None
else
invalid @@ fun _doc ->
format "(* candidate returns None, yet queue is nonempty *)"The auxiliary function remove_minimal kv kvs (link)
checks that the key-value pair kv is a minimal element of
the list kvs and returns this list deprived of this
element. It fails, by raising an exception, if kv is not in
the list or not minimal.
The auxiliary function handle (link)
handles the exceptions raised by remove_minimal and returns
an invalid diagnostic in these cases.
The reference implementation is now complete. There remains to tell Monolith about the operations that we want to test. For each operation, we must provide a specification (that is, roughly, a type), a reference implementation, and a candidate implementation. This is done as follows (test.ml):
let spec = t in
declare "empty" spec R.empty C.empty;
let spec = value ^> key ^> t in
declare "singleton" spec R.singleton C.singleton;
let spec = t ^> t ^> t in
declare "merge" spec R.merge C.merge;
let spec = t ^> nondet (option ((key *** value) *** t)) in
declare "pop" spec R.pop C.pop;In the case of pop, we have used the combinator
nondet (documentation)
to tell Monolith that pop is a non-deterministic operation,
whose reference implementation is written in the unusual style that we
have shown above.
There remains to run the test, which runs forever and prints the problematic scenarios that it detects.
It is worth noting that the result of pop is a composite
value: it is partly concrete, partly abstract, as it is an (optional)
pair of a key-value pair (concrete data that can be observed) and a
priority queue (abstract data that cannot be directly observed). This
does not create any problem: Monolith is able to automatically decompose
this composite value and submit the priority queue component to further
testing.
To illustrate this, let us intentionally introduce the following bug in the candidate implementation:
let pop q =
match pop q with
| Some (kv, q') ->
ignore q';
Some (kv, q) (* return the original queue, unchanged *)
| None ->
NoneThen, the test immediately fails and prints the following scenario:
(* @03: Failure in an observation: candidate and reference disagree. *)
open Bitsets.LeftistHeap.Make(Int);;
#require "monolith";;
module Sup = Monolith.Support;;
(* @01 *) let x0 = singleton 6 11;;
(* @02 *) let (Some ((_, _), x1)) = pop x0;;
(* @03 *) let observed = pop x1;;
(* candidate returns (6, 11), which does not exist *)
The priority queue returned by the first pop operation
is extracted, named x1, and submitted to a second
pop operation, where an observable problem appears.
