Presence at the second OCaml-Paris Meetup
- May 31, 2013
The second OCaml-Paris meetup took place on May 21 at IRILL; I think it was a very interesting event, with good presentations on surprisingly diverse and interesting topics.
A new Coq tactic for inversion
- May 4, 2013
With Pierre
Boutillier, we have been working on a new Coq tactic lately, called
invert. From my point of view, it started as a quest to
build a replacement to the inversion tactic.
inversion is a pain to use, as it generates sub-goals with
many (dependent) equalities that must be substituted, which force the
use of subst, which in turns also has its quirks, making
the mantra inversion H; clear H; subst quite fragile.
Furthermore, inversion has efficiency problems, being quite
slow and generating big proof terms. From Pierreās point of view, this
work was a good way to implement a better destruct tactic,
based on what he did during an internship (report
in French (PDF)).
