From visitors to iterators
- March 14, 2017
I have been asked whether an automatically-generated visitor, as produced by the visitors syntax extension for OCaml, can be used to construct an iterator.
It turns out that this can be done in a simple and efficient manner. (Up to a constant factor, the time complexity of this solution is optimal.) As the problem is interesting and its solution is somewhat nonobvious, I am describing them here.
