Overriding submodules
- November 9, 2013
- Last updated on 2013/11/10
A few days ago Kate Deplaix came to ask me this question: when using
the include trick to override some definition in a module,
how can we also override some definition in a submodule? The answer is
short – just scroll to the last code block – and may be of interest to
some readers.
Module overriding
The proposed use-case is the following: you want to write code that
looks like it uses the module List from the standard
library, but in fact the functions hd and tl
are the variants that return option values, because you
like that style better than catching exceptions.
There is a rather well-known trick to do that, which is to prepend
the following code at the beginning of your source, or in a separate
My_std module you always open first.
module List = struct
include List
let hd = function
| [] -> None
| x::_ -> Some x
endHowever, you may run into problem if the definition you want to override is not directly in the module, but some of its submodule. Let’s consider the following code:
module Toto = struct
let x = 1
module Tata = struct
let y = 2
end
module Titi = struct
let z = 3
end
endSuppose I want to replace Toto.Tata.y to be of type
string rather than int. The obvious thing
doesn’t work.
module Totoverride = struct
include Toto
include Toto.Tata
let y = "2"
end
endError: Multiple definition of the module name Tata.
Names must be unique in a given structure or signature.
The problem is that, while OCaml will let you shadow an existing
let declaration, it does not accept declaring other sorts
of declarations (types, modules, module types…) twice in the same
module. Here a Tata submodule is created in
Totoverride first at the include Toto point,
and then for a second time explicitly.
One manual solution is to use a signature ascription to remove the
Tata submodule from Toto at include time.
include (Toto : sig
val x : int
module Titi : (sig val z : int end)
end)
include Toto.Tata
let y = "2"
end
endThe problem with this solution is that you have to repeat most
Toto’s signature, which leads to a painful maintenance
burden. Not only will changes in Toto’s definition
(addition of new fields) require changes in this place, but the compiler
will not tell you when such changes happen, Totoverride
will just be incomplete with respect to Toto.
module type of
and Destructive substitution
Destructive substitution (with .. := ...) is a newish
feature of the OCaml language, as it was added in 3.12 – released in
summer 2010. The documentation
in the manual is extremely clear and provides good examples, so if
you don’t know about it you should just go read it now.
module type of
was also added in 3.12, and lets you speak about the interface of a
module without defining it explicitly: module type of Foo
is an interface that Foo satisfies.
There are subtleties about the semantics of both these constructions,
so you should not abuse them unless you want to read papers about module
systems – you probably don’t – to understand why your code doesn’t
type-check. However, they can be combined in a perfectly reasonable way
to remove some type or submodules of a module at inclusion time:
module type of Foo with type t := Foo.t is the signature of
Foo, minus the type t, and the same thing
works for with module. This lets us solve our module
overriding problem:
include (Toto : module type of Toto with module Tata := Toto.Tata)
include Toto.Tata
let y = "2"
end
endCompleteness is always hard
This is a neat trick to have in your toolbox, but you should know that it may not satisfy all your module overriding drives. You can remove type and module from a signature, but there are a lot of other OCaml signature items that don’t have a corresponding destructive subtitution: module types, classes, class types and exceptions.
The problem is that it’s not always clear what the intended semantics of destructive substitution should be. For example, I’m not really sure what destructive substitution of exception declarations would mean – exceptions are a kind of blind spot as they don’t appear in types. But in any case, if you try to override everything, you’ll run into this incompleteness and go add your lament to the feature request PR#5460, “Replace/rename/remove module types”.
To be honest, the signature language grows pieces by pieces as needs are justified (and semantics are understood), so it’s not particularly surprising that it is not complete. There was a notable attempt by Norman Ramsey in 2001 to think about what a more self-sufficient signature languages should be, Towards a Calculus of Signatures – with, I just found out, a draft implementation by Jürgen Pfitzenmaier). The good news is that probably the most important construct (destructive substitution of types) has been integrated since, but otherwise things are going at their own pace.
