Florian’s OCaml compiler weekly, 28 April 2023
- April 28, 2023
This series of blog post aims to give a short weekly glimpse into my (Florian Angeletti) daily work on the OCaml compiler. This week, the focus is on compiler messages and backward compatibility.
A tag for quoting inline code
Last week, while I was investigating the breaking change in behavior for polymorphic variants, I have also started a much more boring change: uniformizing the quoting style for inline code in the compiler messages.
Currently, this quoting style is mostly left to the appreciation of
authors of every compiler messages. This has lead the OCaml compiler
messages to be quite heterogeneous, with different messages using
"...", other '...', or `...',
depending on the preference of the initial author.
To make the compiler message, I spent the time to introduce a new
inline_code tag in the set of Format tags used
by the compiler.
With this new tag, the compiler message
fprintf ppf "The external function `%s' is not available" scan be rewritten as
fprintf ppf "The external function %a is not available" Style.inline_code swhich has the advantage of centralizing the styling of inline code fragment in a single location. In particular, this means that we could adapt the styling to the rendering medium (fancy terminal could use fancy styling while basic terminal use a textual quote).
My proposal with this change is currently available as a pull request.
Cleaning-up error messages
Adding an inline_code tag was also a good occasion to
spot small mistakes in error messages. For example, the error message
for non-overriding inheritance
class empty = object end
class also_empty = object inherit! empty endlost a word at some point it time, yielding the following error message
Error: This inheritance does not override any method instance variable
which may confuse reader wondering what is a
method instance variable. The sentence is quite easier to
read once we add back the missing and and plurals
Error: This inheritance does not override any methods or instance variables.
Backward compatibility and polymorphic variants
As discussed last week, I have been working with Gabriel Scherer on a way to preserve backward compatibility for programs that mix open polymorphic variant types and explicit polymorphic annotation in OCaml 5.1:
let f : 'a. [> `X of 'a ] -> 'a = function (`X x) -> x | _ -> assert falseThe backward compatibility hack that we came up with last week is to automatically add the missing annotations:
let f : 'a 'r. ( [> `X of 'a ] as 'r ) -> 'a = function (`X x) -> x | _ -> assert falseHowever, while writing a description of this hack in my pull request, I realized that this change was breaking backward compatibility in another corner case:
let f: 'b. [> `Foo ] -> 'b -> 'b = fun (`Bar|_) x -> xHere the issue is that writing such type annotation let the
typechecker infers that the real type of the row variable is
[> `Foo | `Bar` ]
let f: 'b. [> `Foo | `Bar ] -> 'b -> 'b = fun (`Bar|_) x -> xand not just [> `Foo ]. However, with our hack, this
code will be converted to
let f: 'b 'r. ([> `Foo ] as 'r) -> 'b -> 'b = fun (`Bar|_) x -> xwhere suddenly we cannot widen [> `Foo ] to
[> `Foo | `Bar` ]. And thus the line above fails to
compile with
Error: This pattern matches values of type [? `Bar ]
but a pattern was expected which matches values of type [> `Foo ]
The second variant type is bound to the universal type variable 'a,
it may not allow the tag(s) `Bar
To avoid this regression, Jacques Garrigue proposed to only add annotations to polymorphic variant types that contains references to universal type variables. In other words, with this updated rule
let f: 'b. [> `Foo ] -> 'b -> 'b = fun (`Bar|_) x -> xis kept unchanged because [> `Foo ] does not point to
'b (or any universally quantified type variables).
Contrarily
let f : 'a. [> `X of 'a ] -> 'a = function (`X x) -> x | _ -> assert falseis transformed into
let f : 'a 'r. ([> `X of 'a ] as 'r) -> 'a = function (`X x) -> x | _ -> assert falsebecause [> `X of 'a ] refers to the explicitly
quantified type variable 'a.
Moreover, this rule is still well behaved in presence of nested explicitly polymorphic annotations. For instance, looking at
let nested: 'a.
<m: 'b.
<n:'irr. ('irr -> unit) * ([> `X of 'a | `Y of 'b ] -> 'a) >
> -> 'a = fun o -> (snd o#m#n) (`Y 0)
we can see that the nearest explicit annotation where all universal
variables involved in [> `X of 'a | `Y of 'b] are bound
is the one the method m. Thus the type above is equivalent
with the new rule to:
let nested : 'a.
< m : 'r 'b.
< n : 'irr. ('irr -> unit) * (([> `X of 'a | `Y of 'b ] as 'r) -> 'a) >
> -> 'a = ...On the one hand, I am not sure if the restoration of backward compatibility in OCaml 5.1 is really worth the complexity of this new rule. On the other hand, the new rule is conservative enough that we could use it to emit warnings or hint messages with a sensible resolution if the missing feature for constrained abstract types lands in OCaml.
