First release of PPrint
- February 8, 2013
I am pleased to announce the first official release of PPrint, an OCaml library for pretty-printing textual documents.
A taste of the layout language
At the heart of PPrint is a little domain-specific language of documents. This language has a well-defined semantics, which the printing engine implements. This language rests upon a small number of fundamental concepts.
There are combinators for creating atomic documents. For instance,
string "hello"
is a simple, unbreakable document.
There is also a concatenation operator, which joins two documents. For instance,
string "hello" ^^ string "world"
is a composite document. It is in fact equivalent to
string "helloworld"
So far, nothing very exciting. The next two combinators are more original and interesting.
The first of these combinators, break 1
, is a breakable
space. If printed in flat mode, it produces an ordinary space character;
if printed in normal mode, it produces a newline character.
Yes, there are two printing modes, namely flat mode and normal mode. The printing engine goes back and forth between these two modes. Exactly where and how the engine switches from one mode to the other is controlled by the next combinator.
The second of these combinators, group
, introduces a
choice between flat mode and normal mode. It is a document transformer:
if d
is a document, then group d
is a
document. When the printing engine encounters group d
, two
possibilities arise. The first possibility is to print all of
d
on a single line. This is known as flat mode. The engine
tries this first (ignoring any group
combinators inside
d
). If it succeeds, great. If it fails, by lack of space on
the current line, then the engine backtracks and reverts to the second
possibility, which is to simply ignore the group
combinator, and just print d
. This has subtle consequences:
there might be further groups inside d
, and each of these
groups will give rise to further choices.
This gives rise to an interesting language, where group
is used to indicate a choice point, and the appearance of
break
is dependent upon the choice point(s) that appear
higher up in the hierarchical structure of the document. For instance,
the document:
string "This" ^^ break 1 ^^ string "is" ^^ break 1 ^^ string "pretty.") group (
will be printed either on a single line, if it fits, or on three lines. It will not be printed on two lines: there is just one choice point, so either the two breakable spaces will be broken, or none of them will. By the way, this document can be abbreviated as follows:
string "This" ^/^ string "is" ^/^ string "pretty.") group (
On the other hand, the document:
string "This" ^^
1 ^^ string "is") ^^
group (break 1 ^^ string "pretty.") group (break
could be printed on one, two, or three lines. There are two choice
points, each of which influences one of the two breakable spaces. The
two choices are independent of one another. Each of the words in the
sentence This is pretty.
will be printed on the current
line if it fits, and on a new line otherwise. By the way, this document
1 [
flow string "This" ;
string "is" ;
string "pretty."
There are more combinators, such as nest
, which controls
indentation, and it is relatively easy to roll your own combinators on
top of those that are provided.
One limitation of the library is that the document must be entirely built in memory before it is printed. So far, we have used the library in small- to medium-scale applications, and this has not been a problem. In principle, one could work around this limitation by adding a new document constructor whose argument is a suspended document computation.
Acknowledgements
The document language and the printing engine are inspired by Daan Leijen’s PPrint library, which itself is based on the ideas developed by Philip Wadler in the paper A Prettier Printer.
PPrint was written by François Pottier and Nicolas Pouillard, with contributions by Yann Régis-Gianas, Gabriel Scherer, and Jonathan Protzenko.
Installation
The library is available online (source
code, documentation),
and can also be installed via OPAM: just type
opam install pprint
if you already have a working OPAM
installation.
Have fun! Feel free to make comments, suggestions, and to let me know if and how you are using this library.
A Final Example
For a larger example, here is the code of the file
PPrintTest.ml
included in the distribution (with the
maximum line width adapted for this blog post):
open PPrint
let document =
2 1
prefix string "TITLE:")
(string "PPrint")
hardline
^^2 1
prefix string "AUTHORS:")
("François Pottier and Nicolas Pouillard")
(utf8string
hardline
^^2 1
prefix string "ABSTRACT:")
(1 (words
flow "This is an adaptation of Daan Leijen's \"PPrint\"
by Philip Wadler in \"A Prettier Printer\". For more
information about Wadler's and Leijen's work,
please consult the following references:")
^^2 (
nest 1)
twice (break
^^1) (fun s -> nest 2 (url s)) [
separate_map (break "http://www.cs.uu.nl/~daan/pprint.html";
"http://homepages.inf.ed.ac.uk/wadler/papers/prettier/prettier.pdf";
^^1)
twice (break
^^1 (words
flow "To install PPrint, type \"make -C src install\".
ocamlfind is required.")
^^1)
twice (break
^^1 (words
flow "The documentation for PPrint is built by \"make doc\"
and is found in the file doc/index.html.")
hardline
let () =
1. 60 stdout document;
ToChannel.pretty flush stdout
It produces the following output:
TITLE: PPrint
AUTHORS: François Pottier and Nicolas Pouillard
ABSTRACT:
This is an adaptation of Daan Leijen's "PPrint" library,
Wadler in "A Prettier Printer". For more information about
Wadler's and Leijen's work, please consult the following
references:
prettier.pdf
To install PPrint, type "make -C src install". ocamlfind
is required.
The documentation for PPrint is built by "make doc" and is
