A toy type language (3) using Fix to compute variance
- January 21, 2014
We can now demonstrate the Fix library, used to compute arbitrary fixpoints, by implementing variance computation for the toy type system of our first post.
Getting Fix
Fix is available in OPAM, so obtaining it is as simple
as:
opam install fixThe following command-line will compile a test file and run the resulting program:
ocamlfind ocamlc -package fix -linkpkg test.ml && ./a.outSome definitions
We first need to define what is variance, as well as the various operations (negation, composition).
type variance =
  | Inv
  | Co
  | Contra
  | Bi
let join a b =
  match a, b with
  | Inv, _
  | _, Inv ->
      Inv
  | Bi, x
  | x, Bi ->
      x
  | x, y ->
      if x = y then
        x
      else
        Inv
let minus = function
  | Inv -> Inv
  | Co -> Contra
  | Contra -> Co
  | Bi -> Bi
let dot a b =
  match a, b with
  | Inv, Bi ->
      Bi
  | Inv, _ ->
      Inv
  | Co, b ->
      b
  | Contra, b ->
      minus b
  | Bi, _ ->
      Bi
;;We will now recall our toy language of structural types:
type typ =
  | Sum of typ * typ
  | Prod of typ * typ
  | Unit
  | Var of string
  | App of string * typ list
  | Fun of typ * typ
type defs =
  (string * string list * typ) list
let def_list =
  [ "list", ["a"], Sum (Unit, Prod (Var "a", App ("list", [Var "a"]))) ]The compute_variance
function
let rec compute_variance
    (valuation: string -> variance)
    (t: typ)
    (var_for_ith_param: string -> int -> string)
    (v: string): variance
  match t with
  | Prod (t1, t2)
  | Sum (t1, t2) ->
      let v1 = compute_variance valuation t1 var_for_ith_param v in
      let v2 = compute_variance valuation t2 var_for_ith_param v in
      join v1 v2
  | Unit ->
      Bi
  | Var v' ->
      if v' = v then Co else Bi
  | App (t0, ts) ->
      let vs = List.mapi (fun i t ->
        let formal = valuation (var_for_ith_param t0 i) in
        let effective = compute_variance valuation t var_for_ith_param v in
        dot formal effective
      ) ts in
      List.fold_left join Bi vs
  | Fun (t1, t2) ->
      join (minus v1) v2In the context of Fix, we call variables the unknowns in
the system of equations whose value we wish to compute. In the last
example, the variables are va, vb,
vc and vd. When writing the definition of
list a, we will say that a is a
parameter for the type list.
In our toy example, Fix variables are of type
string.
When computing the variance of a variable in a given type, we need to
access the value of the other variables. In the last example, the
equation for vc mentions va and
vb, meaning we will need both values when evaluating the
right-hand side of the vc = equation. This is the purpose
of the valuation function.
Another auxiliary function that compute_variance needs
is var_for_ith_param, which returns the variable associated
to the i-th parameter of another type. For instance,
var_for_ith_param t 1 would return vb in the
last example.
The definition of this function is straightforward; the only
difficult case is App. We use List.mapi as we
treat the general case of n-ary type applications; we just
need to perform a “join” of all computed variances for all type
parameters.
Setting up Fix
Fix uses a functorized interface, the documentation of
which is available online.
Fix requires imperative maps over its variables; our toy
example defines imperative String maps using a reference on
a Map.Make(String).t; this is boring so I won’t include it
here.
Fix also requires the user to define a module that has
type PROPERTY. In the Fix jargon, properties
are the values for the variables that we wish to solve. In our
particular example, a property is a variance. The definition of the
module is straightforward.
module P = struct
  type property = variance
  let bottom = Bi
  let equal = (=)
  let is_maximal = (=) Inv
endSetting up Fix is done through a double-functor
application:
module Solver = Fix.Make(IStringMap)(P)How do we define a system of equations for Fix? A system
of equations is a function that maps a variable (e.g. va)
to a corresponding property (variance), which is obtained by calling
compute_variance on the corresponding right-hand-side.
However, computing a property requires, as we mentioned earlier,
accessing the values for the other variables: computing va
requires knowing the values for vb, vc,
vd, as well as the “current” value of va.
Computing a right-hand side therefore requires having a
valuation for the other variables.
type rhs = valuation -> propertyThus, a system of equations maps variables to right-hand sides.
type equations = variable -> rhsNaturally, a valuation maps a variable (e.g. va) to a
property (e.g. co).
type valuation = variable -> propertyLet us now write the equations function:
let solve (defs: defs) =
  (* Build the list of equations. *)
  let equations = fun (var: string) ->
    let _, _, t =
      (* Find the type definition this variable belongs to. *)
      List.find (fun (_, params, _) ->
        List.exists ((=) var) params
      ) defs
    in
    fun valuation ->
      compute_variance valuation t (var_for_ith_param defs) var
  in
  (* Solve them. *)
  let valuation = Solver.lfp equations in
  valuationThe equations function maps a variable var
to a right-hand side. This requires finding, in our list of mutually
recursive definitions, the type which this variable belongs to (that is,
mapping va to t), and extracting the
definition of the type (that is, extracting the definition of
t). We then return a function that takes a valuation and
computes the variance of the variable in its definition (that is, the
value of va under a valuation).
The final call to solve the system is done through
Solver.lfp, which just takes the equations
function. The amazing part is that we never needed to add the set of
variables into the map: this is all done under-the-hood by
Fix!
Play with it
The source code is available here.
