ARM MOREDETOUR0244
"DpDatadW Rfe DetourR DpDatadW DetourWW Rfe"
Cycle=Rfe DetourR DpDatadW DetourWW Rfe DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DetourR DpDatadW DetourWW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%y2=y;
%x3=x;
P0 | P1 | P2 | P3 ;
LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2 | LDR R0,[%x3] ;
EOR R1,R0,R0 | LDR R1,[%y1] | STR R0,[%y2] | MOV R1,#2 ;
ADD R1,R1,#1 | EOR R2,R1,R1 | | STR R1,[%x3] ;
STR R1,[%y0] | ADD R2,R2,#1 | | ;
| STR R2,[%x1] | | ;
| MOV R3,#3 | | ;
| STR R3,[%x1] | | ;
exists (0:R0=2 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=0 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R1=2 /\ 3:R0=3 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=2 /\ 1:R1=1 /\ 3:R0=3 /\ [x]=2)
