Test MOREDETOUR0216
ARM MOREDETOUR0216
"DpDatadW Rfe DpDatadW DetourW DetourRW Rfe"
Cycle=Rfe DpDatadW Rfe DpDatadW DetourW DetourRW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe DpDatadW DetourW DetourRW Rfe
%x0=x; %y0=y;
%y1=y; %x1=x;
%x2=x;
%x3=x;
 P0           | P1           | P2           | P3           ;
 LDR R0,[%x0] | LDR R0,[%y1] | MOV R0,#2    | LDR R0,[%x3] ;
 EOR R1,R0,R0 | EOR R1,R0,R0 | STR R0,[%x2] | MOV R1,#3    ;
 ADD R1,R1,#1 | ADD R1,R1,#1 |              | STR R1,[%x3] ;
 STR R1,[%y0] | STR R1,[%x1] |              |              ;
              | LDR R2,[%x1] |              |              ;
              | MOV R3,#4    |              |              ;
              | STR R3,[%x1] |              |              ;
exists (0:R0=2 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=4 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=0 /\ [x]=4) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=4) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=4 /\ [x]=3) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=2 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=2 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=4 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=4 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=4) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=4 /\ [x]=3) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=0 /\ [x]=4) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=3 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=2 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=0 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=2 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=2 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=4 /\ [x]=2) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=1 /\ 3:R0=4 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=0 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=0 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=2 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=2 /\ 3:R0=4 /\ [x]=3) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=0 /\ [x]=2) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=0 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=1 /\ [x]=2) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=1 /\ [x]=4) \/ (0:R0=4 /\ 1:R0=1 /\ 1:R2=3 /\ 3:R0=2 /\ [x]=4)
