ARM DETOUR0378 "DetourW DpAddrdR Fri Rfe DpDatadW Wse" Cycle=Rfe DpDatadW Wse DetourW DpAddrdR Fri Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DetourW DpAddrdR Fri Rfe DpDatadW Wse { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#2 | MOV R0,#3 | LDR R0,[%y2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | ADD R1,R1,#1 ; EOR R2,R1,R1 | | STR R1,[%x2] ; LDR R3,[R2,%y0] | | DMB ; MOV R4,#1 | | LDR R2,[%x2] ; STR R4,[%y0] | | ; exists (0:R1=3 /\ 0:R3=0 /\ 2:R0=1 /\ 2:R2=2) \/ (0:R1=3 /\ 0:R3=0 /\ 2:R0=1 /\ 2:R2=3)
