ARM DETOUR0067 "DetourW PosRR DpDatadW Rfe DpAddrdR Fre" Cycle=Rfe DpAddrdR Fre DetourW PosRR DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DetourW PosRR DpDatadW Rfe DpAddrdR Fre { %x0=x; %y0=y; %x1=x; %y2=y; %x2=x; } P0 | P1 | P2 ; MOV R0,#1 | MOV R0,#2 | LDR R0,[%y2] ; STR R0,[%x0] | STR R0,[%x1] | EOR R1,R0,R0 ; LDR R1,[%x0] | | LDR R2,[R1,%x2] ; LDR R2,[%x0] | | ; EOR R3,R2,R2 | | ; ADD R3,R3,#1 | | ; STR R3,[%y0] | | ; exists (0:R1=2 /\ 2:R0=1 /\ 2:R2=0) \/ (0:R1=2 /\ 2:R0=1 /\ 2:R2=1)
