AArch64 MP+dmb.sy+pos-addr-ctrl-fri-rfi "DMB.SYdWW Rfe PosRR DpAddrdR DpCtrldR Fri Rfi Fre" Cycle=Rfi Fre DMB.SYdWW Rfe PosRR DpAddrdR DpCtrldR Fri Relax= Safe=Rfi Rfe Fri Fre PosRR DMB.SYdWW DpAddrdR DpCtrldR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMB.SYdWW Rfe PosRR DpAddrdR DpCtrldR Fri Rfi Fre { 0:X1=x; 0:X3=y; 1:X1=y; 1:X5=z; 1:X7=x; } P0 | P1 ; MOV W0,#2 | LDR W0,[X1] ; STR W0,[X1] | LDR W2,[X1] ; DMB SY | EOR W3,W2,W2 ; MOV W2,#1 | LDR W4,[X5,W3,SXTW] ; STR W2,[X3] | CBNZ W4,LC00 ; | LC00: ; | LDR W6,[X7] ; | MOV W8,#1 ; | STR W8,[X7] ; | LDR W9,[X7] ; Observed y=1; x=1; 1:X9=1; 1:X6=2; 1:X2=0; 1:X0=1;
