AArch64 LB+data+pos-addr-fri
"DpDatadW Rfe PosRR DpAddrdR Fri Rfe"
Cycle=Rfe PosRR DpAddrdR Fri Rfe DpDatadW
Relax=
Safe=Rfe Fri PosRR DpAddrdR DpDatadW
Prefetch=0:x=F,0:y=W,1:y=F,1:x=W
Com=Rf Rf
Orig=DpDatadW Rfe PosRR DpAddrdR Fri Rfe
0:X1=x; 0:X3=y;
1:X1=y; 1:X5=x;
P0 | P1 ;
LDR W0,[X1] | LDR W0,[X1] ;
EOR W2,W0,W0 | LDR W2,[X1] ;
ADD W2,W2,#1 | EOR W3,W2,W2 ;
STR W2,[X3] | LDR W4,[X5,W3,SXTW] ;
| MOV W6,#1 ;
| STR W6,[X5] ;
Observed
y=1; x=1; 1:X4=0; 1:X2=0; 1:X0=1; 0:X0=0;
