AArch64 C-Will03
(* Test a particular case of linux atomic_add_return, check failure
of SC (discarded in case of LL/SC loop.
Loop is unrolled once and value read in y by P0 is not discarded *)
0:X1=x; 0:X2=y;
1:X2=y; 1:X1=x;
P0 | P1 ;
MOV W0,#1 | MOV W0,#2 ;
STR W0,[X1] | STR W0,[X2] ;
MOV W3,#1 | DMB ISH ;
LDXR W4,[X2] | LDR W3,[X1] ;
ADD W3,W4,W3 | ;
STLXR W5,W3,[X2] | ;
CBNZ W5,Fail0 | ;
DMB ISH | ;
B Exit0 | ;
Fail0: | ;
MOV W3,#1 | ;
LDXR W8,[X2] | ;
ADD W3,W8,W3 | ;
STLXR W9,W3,[X2] | ;
Exit0: | ;
locations [y;0:X8;]
exists (0:X4=0 /\ 1:X3=0/\ ~(0:X5=0) /\ 0:X9=0)
